I just upgraded a HotSpot system running 2.9.34 using the routeros-x86-2.9.35.npk file. After the reboot the system (running on a WRAP board) did not come up again. I power-cycled the router, and it came up again.
HOWEVER: “/system packages” does show the “combined” package installed, but this is missing a lot of packages, amongst them the hotspot package! I.e. it’s not that the hotspot package is disabled - it’s just not there. Actually the only packages in there are those:
[admin@MikroTik] > system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-x86 2.9.35
1 X rstp-bridge-test 2.9.35
2 web-proxy 2.9.35
3 system 2.9.35
4 routerboard 2.9.35
5 ntp 2.9.35
6 wireless 2.9.35
7 ups 2.9.35
8 synchronous 2.9.35
9 X webproxy-test 2.9.35
The system identity has been reset to “MikroTik”, too.
The log does contain five empty log lines from directly after the start - just date/time, topic “system info”, but no more content.
The routeros-x86-2.9.35.npk file has a size of 11.157.244 bytes, so the size seems to fit the earlier packages containing everything. I have downloaded this file on November 6th at 15:18 (GMT+1).
Has anyone seen something similar?
Any comments from MikroTik?
Does sending in a supout make sense here?
Best regards,
Christian Meis
