problem with same Vlan on bridge and interface
Hi Guys,
Could an expert please help me?
This is the Setup
I have a Mikrotik RB750GL. I have configured this with 2 Vlans (Vlan Tag 10 & 20) these have been associated with bridge1 that I have created, I have also associated bridge1 to interface 1. I then connected to interface 1 an Access Point that has also been configured to accept these vlan tags 10 & 20. Then depending on the tag it associates the traffic to the correct SSID.
Due to further configuration on the Mikrotik such as DHCP pools etc… these have not mentioned when you connect to these different SSID’s you get the different networks, (vlan 10 & 20) I can also ping the Mikrotik this is what I want.
This is where I am stuck…
I would like to have a PC connected to port 2 on the Mikrotik, the PC must only talk on the network associated to Vlan 20. How do I associate this interface to vlan20? I ask this as this VLAN has previously been associated to bridge1. I don’t see how I can associate a Vlan to bridge1 and Interface 2.
Regards
Hi Guys,
I finally managed to resolve this issue, should any one be interested.
I will gladly share.
Regards
share please :slight_smile:
