Problem with saved file
I have a problem with a Mikrotik RB750Gr2.
If I save a file or a backup configuration, after reboot I don’t find any files in file list!
This mikrotik was update to a last firmware, but is the same.
Make license backup first, netinstall with nand format. It may help.
This is normal behavior. Files will only be saved if you put them in the Flash folder. The devices which have SPI FLASH not NAND do not have so much disk space, therefore the uploads go to RAM, and only get stored if you put them in the Flash folder.
