I have one problem with my script. Best way will be paste code here :
# Do not include '.rsc', it is appended automatically
:local filename "wireless-interface-monitor"
# Internal processing below...
:local line
:local word
:local contents
:local fileindex 1
/interface wireless {
:set contents "/interface wireless monitor\n"
# loop through wireless interfaces, getting their advanced (plus basic) settings
:foreach r in=[monitor wlan1 as-value] do={
:set line ""
:foreach i in=[:toarray $r] do={
:set word [:pick [:tostr $i] 0 [:len [:tostr $i]]]
:set line ([:tostr $line] . [:tostr $word] . "\n")
# end foreach i
# delete last character "\n"
:set line ([:pick [:tostr $line] 0 ([:len [:tostr $line]]-1)])
# if contents + line is over filesize limit, write out to file
:if (([:len [:tostr $contents]] + [:len [:tostr $line]]) > 4096) do={
/system identity export file=($filename . $fileindex)
# wait for file to appear (this is needed)
:while ([:len [/file find name=($filename . $fileindex . ".rsc")]] = 0) do={}
/file set ($filename . $fileindex . ".rsc") contents=[:tostr $contents]
:set fileindex ($fileindex + 1)
# append line to contents
:set contents ([:tostr $contents] . [:tostr $line])
# write remaining contents
:if ([:len $contents] > 0) do={
# /interface wireless
I think the problem is on line where I setting word and line. *Note that variable word is there because of debug I had the code of word inside “set line” code.
This is what I got from file:
notify-external-fdb=true
So I think that the script badly joining strings in variable line.
The good output should be:
.id=*4
band=2.4ghz/g
Could someone help me?
