I need to delete a list of addresses using index number.
Using the command from the terminal works, example:
/ip firewall address-list remove numbers=6
but
but using it in a script does not work.
possible solutions?
Thanks!
but
possible solutions?
Thanks!
may be “no such item”
use this command to see what is the output
:put [/ip firewall address-list remove numbers=6 ]
Index numbers are put in buffer after print command. You cannot blindly use these numbers in script.
Use find command instead, based on properties:
/ip firewall address-list remove [ find list=<name> address=<address> ]
