Problem with sempron and aopen motherboard
hello comrades
do I have problems with a motherboard aopen ak77-600n and the routeros in ide flash, does any configuration that I prove mark me disk boot fail, is the bios apparently, has somebody had a similar problem? the firmware gives the bios it upgrades it to the but recent without solving this my problem.
I am using the routeros version 2.8.48 and the chipset of the motherboard it is a VIA KT600.
Thank you!!
Hi The same trouble for me !!
am try to install router OS 2.8.28 on Asus Board with AMD SEPTRON 2800 + . After the installation , the system reboot imidiately when the
kernel is loading .. I try the 2.8.27 but is the same trouble … I have 5 board with this cpu … Somebody have a solution .. :confused:
Ho the support for scci would very fine !! for a heavy duty solution.
is just a sugestion :sunglasses:
