I'm trying to configure a RB750 with this simple configuration:
Ether1 is connected by /30 to a radio uplink back to the rest of the network and the internet
Ether2 (and also 3-5 once this is working) will be connected on a bridge that will provide connectivity to tenants.
A /29 address will be assigned to the bridge.
After configuring this setup, it seems as though no packets would be forwarded from Ether1 to a tenant on Ether2 on the bridge and vice-versa.
I could ping the IP Address assigned to the bridge, but not the tenant's IP, and the tenant could not access the rest of the network or the internet.
xxx.xxx.187.229 is the network side of the /30
xxx.xxx.186.41 is the /29 address assigned to the bridge
Thanks.
-- James
Here is the configuration:
aug/31/2013 13:32:56 by RouterOS 6.2
software id = EAVP-MEQY
add name=tenants-bridge
set 1 name=ether2 poe-out=off
set 2 name=ether3 poe-out=off
set 3 name=ether4 poe-out=off
set 4 name=ether5 poe-out=off
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password=""
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no
permissions=owner signup-allowed=no time-zone=-00:00
add bridge=tenants-bridge interface=ether2
add address=xxx.xxx.186.41/29 comment="TENANTS SUBNET" interface=
tenants-bridge network=xxx.xxx.186.40
add address=xxx.xxx.187.230/30 comment="DOWNLINK TO 13701" interface=
ether1-gateway network=xxx.xxx.187.228
set allow-remote-requests=yes max-udp-packet-size=512
/ip dns static
add address=192.168.88.1 name=router
/ip proxy
set parent-proxy=0.0.0.0
add distance=1 gateway=xxx.xxx.187.229
/ip service
set api disabled=yes
/queue interface
set ether1-gateway queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
/system identity
set name=MikroTik-13400
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set tenants-bridge disabled=yes display-time=5s
set ether1-gateway disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/system ntp client
set enabled=yes primary-ntp=xxx.xxx.184.19
/tool mac-server
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
/tool mac-server mac-winbox
