Problem with SIS Motherboards
I’m wondering, does anyone had a problem with motherboards based on SIS chipset. The Mikrotik RouterOS doesn’t reboot on these motherboards, it just hangs, but not restarting. If I do a hard reboot (imediate OFF and ON) it starts without any problem, but if I write system reboot, what I can see is system restarting … and that’s it, I have tested two different Motherboards based on SIS chipset.
Regards.
I think if you install routerBoard package al will be good
The routerboard package was installed, but the problem is not solved, I have tested 10 different motherboards based on SIS chipset, and all behave the same.
Regards.
I use in one router a SIS530 chipset with amd k62-500 an mtik 2.9.22 and it reboots fine…but before install routerboard package not.
