hi
i configured snmp for devices in dude
it works well for a few days;suddenly most device snmp don’t work
I tried both the pc and the router
This has happened several times and i should reboot pc or router to be active again.
What is the reason for this problem?
nobody !!??
I have had once or twice where polling devices from the dude has stopped but it is so rare I never tried to fix it.
In your case it seems repeatable but the reason for it is completely unknown. Maybe there is a device that is not actually following the SNMP protocol. Divide and conquer is about the only recommendation I have. You could disable half your probes and see if it crashes then disable the other half of the probes. If you find that certain probe types are causing issues you could report them back here so we can hear about them.
GL
Lebowski
