Hi all!
I’m a new RouteOS user, using a RouterBoard750GL as router at home.
I thought it would be nice to be able to use the RB as SSH-jumpgate towards my Linux-computer on the LAN, so that I 1) dont have to have them open towards Internet 2) mock around with port-mappings…
However, I have problems connection to my desktop-machine using the /system ssh client in ROS. It works connection to other SSH-servers on my LAN, and others on Internet.
ROS is version 5.6 and the SSH server is openSSH 5.8p1.
Have anyone else had simillar problems?
The symtom is that when I connect to the server, nothing happens, nothing shows in the log on the server. No timeout, nothing. Looking at the log with higher log-verbose, theres nothing different between the ROS-client, and another openssh-client on the LAN, apart from the identified client-version. and the fact that the openssh-client gets a prompt, asking for username/passwd.
If I connect from ROS with invalid username, that is the only thing showing in the log on the server, nothing else…
I guess there is a problem with the ROS ssh implementation? or that this version o open-ssh cant cope with it…
Would be nice though to know if anyone else has this problem…
/Daniel
