I am using Mikrotik RB450G with RouterOS 6.45.6. I can’t connect to my Mikrotik using SSTP VPN.
Firewall is set up as below:
The first role is :
chain=input action=accept protocol=tcp dst-port=443 log=no log-prefix="
and then is drop for the rest:
chain=input action=drop in-interface=Eth1-Wan log=no log-prefix=“”
When i turn off last role (drop) - all working fine, but when is enable i can’t connect to the network.
Is there anyone who can help me?
Thank you in advance
Regards,
Adrian
Maybe you ve changed the default SSTP port from 443 to another one?
bpwl
January 2, 2022, 10:41pm
3
Add this before the drop action (it is in the default firewall), you probably also need “established”
from default
or from wiki
add chain=input connection-state=invalid action=drop \
comment="Drop Invalid connections"
add chain=input connection-state=established action=accept \
comment="Allow Established connections"
anav
January 3, 2022, 5:08pm
4
@bpwl Without seeing the config, you are just guessing. WHY?
Please post config
(ensure no public IPs are exposed).
The only rreason this thread got resurrected after 2 (TWO) years is because someone posted to create visibility for the links in his signature…
So sad.
anav
January 4, 2022, 12:28am
6
Yeah my bad also, it was a dead thread…good point holvoeten!!
