Problem with state cap in interface List
Subject: RouterOS 6.49.20 legacy CAPsMAN - local CAP interface on CAPsMAN manager stays disabled while remote CAPs work
I have a reproducible issue with legacy CAPsMAN on RouterOS 6.49.20.
Hardware
  • CAPsMAN Manager: RB941-2nD (hAP lite)
  • Remote CAP #1: cAP lite
  • Remote CAP #2: cAP ac
All devices run RouterOS 6.49.20 (long-term).
Configuration
  • Legacy /caps-man (wireless package)
  • Local forwarding
  • Dynamic provisioning
  • cAP lite and cAP ac are discovered and provisioned correctly.
  • cAP ac also has a virtual 5 GHz SSID (slave configuration), which works correctly.
What works
  • Remote CAPs connect successfully.
  • Both radios on cAP ac are provisioned.
  • Clients connect normally.
  • Roaming works.
  • Virtual SSID on cAP ac works.
Problem
I would also like the local wireless interface on the CAPsMAN manager (hAP lite) to be managed by CAPsMAN.
When I enable CAP on the hAP lite:
/interface wireless cap
enabled=yes
interfaces=Willage
caps-man-addresses=127.0.0.1
(or using the manager IP address instead of 127.0.0.1)
the local wireless interface changes to:
managed by CAPsMAN
X Willage
The interface becomes disabled and stops transmitting.
If I disable CAP, the same interface immediately starts broadcasting again using the local configuration.
Observations
  • Remote CAP list contains only:
    • cAP lite
    • cAP ac
The hAP lite never appears as a Remote CAP.
Remote radios are visible and provisioned correctly.
The local wireless interface receives CAPsMAN parameters (SSID, channel etc.), but never becomes Running.
Another thing I noticed
In CAPsMAN → Interfaces I see:
cap6   RMB
cap9   MB
cap10  MB
cap11  B
where
  • cap6 = cAP lite
  • cap9 = cAP ac 2.4 GHz
  • cap10 = cAP ac 5 GHz
  • cap11 = virtual AP
However, on the cAP ac itself I see:
wlan1  RS
wlan2  RS
wlan3  DRS (Virtual)
Everything works correctly, but CAPsMAN Interfaces do not show "R" for cap9/cap10.
Questions
  1. Is it officially supported in RouterOS 6.49.x (legacy CAPsMAN) to have the CAPsMAN manager manage its own local wireless interface as a CAP?
  2. If yes, what additional configuration is required?
  3. Is the missing "R" flag on cap9/cap10 expected behaviour with local forwarding, or is it a display bug?
Thank you.
cap6 CAP lite
cap11,12 CAP ac
