Hi
I have 5 PTP Wireless Links!
These POEs are connected to a 5 port switch
The SXT will exit the circuit after a few hours
I don’t have ping
Can’t connect to it
Winbox can’t find it
It needs to be reboot once to come back to the network
And after a few hours the same thing happens again
Do you try to connect Wireless of via cable?
Does your Switch have any log?
Yes But Need To Reboot
Nohave log
As you mention PoE, does your switch provide power to the SXTs via PoE? if so, is it a Mikrotik switch (such as hEX PoE lite or the same hardware in different mechanical case called PowerBox) providing “passive PoE”, or some other vendor’s switch providing the 802.3af or at PoE?
If it is a Mikrotik’s one, given that each SXT lite 5 takes about 0.3 A at 24 V, does your power supply provide enough power for all the SXT and the hEX PoE lite itself? The power adaptor bundled with hEX PoE lite has enough power for this but maybe you use something else?
Hello
Thank you for your response
Not all POEs are Mikrotik themselves
A NETBOX device, a BaseBox device, a SXT Lite 5
A NanoBridge device
A PoweStation device
Included in this switch
Switch 8 port Dlink
