I’m having problems accessing the router RB450G through winbox.
For testing, I enter the router using the serial port and through console commands I have executed the command “system reset-configuration” in order that the router is set to factory default, but now I can not access the router using the winbox, even I used the mac address but I can not access the router using the winbox
system reset command probably erased the configuration the device came with.
you can try to connect to the router (make sure to use ports 2-5, not port 1) from your PC with Winbox. Click the […] button and Winbox will find the device. Click on the MAC address to connect. You will then be able to see the IP addresses of the device, and if they are removed, add them back.
