Dear all,
I have 2 PCs. PC_A is inside, PC_B is outside. When i connect from PC_A to PC_B by teamviewer and send file so veryfast. But if I connect from PC_B to PC_A and send file so very slow.
I don’t know where is problem.
Please advice me
Thanks all
For what exactly input and output speed do you pay your providers on PC A and PC B? If you have on PC B assymetric channel, then this is a reason why your speed is low at one side.
Network topology is below: PC_A ---- Mikrotik Router ---- Internet ------ Another Router ------ PC_B
WAN IP address of Mikrotik Router and Another Router are public ip
PC_A connected to PC_B by teamviewer and send file so fast
PC_B connected to PC_A by teamviewer and send file so slow
When replace Mikrotik router by Draytek Router so 2 direction OK
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=48ms TTL=58
Tracing route to 8.8.8.8 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.10.250
2 <1 ms <1 ms <1 ms 192.168.10.254
3 1 ms 1 ms 1 ms 10.41.239.8
4 1 ms 1 ms 1 ms 27.68.245.49
5 36 ms 31 ms 31 ms 27.68.232.157
6 33 ms 31 ms 31 ms 27.68.255.53
7 31 ms 31 ms 31 ms 27.68.244.50
8 47 ms 47 ms 47 ms 27.68.250.245
9 30 ms 30 ms 30 ms 27.68.249.57
10 31 ms 31 ms 31 ms 27.68.250.242
11 31 ms 31 ms 31 ms 72.14.196.68
12 30 ms 30 ms 30 ms 74.125.242.33
13 48 ms 48 ms 48 ms 108.170.237.229
14 48 ms 48 ms 48 ms 8.8.8.8
Speed Test
VietNam to HongKong
Ping 22ms
Download: 64.43 Mbps
Upload: 64.03 Mbps
When some connections are inexplicably slow, or do not work at all (e.g. some sites do not load), you should check the MTU of your path.
E.g. when your ISP uses PPPoE the MTU of the hop to the ISP is often less than 1500. So the router is at a point where the MTU decreases and should fragment the packets, but unfortunately many OS have default DF bit set preventing the router from doing that.
This results in ICMP messages that are often handled incorrectly by overzealous firewalls, and then it works incorrectly.
When you are affected by this, it can help to put this rule in the router:
