I have a problems with viruses on my network. But I cannot find from wich IP address are they comming and via wich port, becouse torch option on mikrotik dont work properly. Does anyone know what should I do to fix this problem. Thanks
and it’s even worst with another router:
If you select all options in torch, not all traffic will be shown. Uncheck port and the totals should match.
it shows only if I turn off all options. but then dont shows Rx
1
2
