Problem with transparent proxy
I want to create a transparent proxy, I am following this commands
ip firewall nat add in-interface=ether1 dst-port=80 protocol=tcp action=redirect to-ports=8080 chain=dstnat
ip proxy set enabled=yes port=8080
Once I do that I write this command to reset the html pages in the proxy (I guess the command is for that)
[admin@MikroTik] > /ip proxy reset-html
but when I write: /ip proxy re-----it doesn´t allow me to write reset…it allows me to write refresh or something like that but not reset. Previously I configured the user manager in the rb 433 but I changed the port to 808, otherwise I couldn´t make it work, should I change the dst-port=80 to 808? or it has nothing to do with the proxy?
If it doesn´t, what could be the problem?
Thanks for your help
has anybody faced this problem before?..
I am checking the web proxy settings and I can see that it is enabled, but i don´t know how to make sure it is working…
the only pages html that I can see are the ones of the login, status, etc of the hotspot but nothing related to other websites such as google.
anyone?
Thanks for your attention
I’m very interested! I would love to find out more inforamtion related to this topic.
Thanks in advance.me too, I need more detailed info.
[u]calcul credit immobilier courtier taux simulation de france pret[/u]Une simulation credit immobiler de France a faire un pret.[u]calcul credit immobilier courtier taux simulation de france pret[/u]
To check webproxy goto system logging and enable webproxy loging. Check logs. You wil then see all logs for the cache.
tks ummar…i can see the files in the cache…
but i still don´t understand why I can´t reset the files
tks in advance for your hep
you do not need any reset or something for webproxy - you enabled it, set port and this is it. you oucld reset for hotspot, but that is completely different matter.
ok janisk got it…tks
