Hello there,
My situation is I have two ISP
ISP 1 - IP1, interface WAN1
ISP 2 - IP2, interface WAN2
Inside I have two private networks
LAN1: 10.0.0.0/24
LAN2: 10.20.30.0/24
I have configured the router to work like this
add action=masquerade chain=srcnat out-interface=WAN1 src-address=10.20.30.0/24
add action=masquerade chain=srcnat out-interface=WAN2 src-address=10.0.0.0/24
add distance=1 gateway=ISP1-gw routing-mark=RLAN1
add distance=1 gateway=ISP2-gw routing-mark=RLAN2
add distance=1 gateway=ISP1-gw, ISP2-gw
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=!10.0.0.0/24 new-routing-mark=RLAN1 src-address=10.20.30.0/24
add action=mark-routing chain=prerouting dst-address=!10.20.30.0/24 new-routing-mark=RLAN2 src-address=10.0.0.0/24
Its working fine:
LAN1 goes via ISP1
LAN2 goes via ISP2
LAN1 sees LAN2 with no problem.
All good, BUT
I have one WEB server in LAN1 and one SQL server in LAN2 and …
Port forwarding does not work ? It was working when I had only one ISP to server both local networks, now its not
Can you advice me how to do what I want and make port-forwarding to work
