problem with upgrade RB800 OS from 4.2 to 4.5
Hi all
i have RB800 need to upgrade it from OS4.2 to 4.5 .. i have downloaded the new packages from Mikrotik web site and past it in the file list via winbox and then reboot the RB800 ,, the new packages now uploaded to the file list but the OS still show 4.2 , bellow the results :
[admin@MikroTik] > file print
NAME TYPE SIZE CREATION-TIME
0 4.5/advanced-t... package 140409 jan/02/1970 00:02:04
1 4.5/ppp-4.5-pp... package 335481 jan/02/1970 00:02:06
2 4.5/routerboar... package 184773 jan/02/1970 00:02:06
3 4.5/routing-4.... package 485335 jan/02/1970 00:02:07
4 4.5 directory jan/02/1970 00:02:04
5 4.5/security-4... package 433159 jan/02/1970 00:02:07
6 4.5/system-4.5... package 8387200 jan/02/1970 00:02:16
7 4.5/calea-4.5-... package 24307 jan/02/1970 00:02:04
8 4.5/ups-4.5-pp... package 66855 jan/02/1970 00:02:16
9 4.5/dhcp-4.5-p... package 152119 jan/02/1970 00:02:05
10 4.5/user-manag... package 485720 jan/02/1970 00:02:16
11 4.5/gps-4.5-pp... package 14163 jan/02/1970 00:02:05
12 4.5/wireless-4... package 681752 jan/02/1970 00:02:17
13 4.5/hotspot-4.... package 233683 jan/02/1970 00:02:05
14 4.5/ipv6-4.5-p... package 277472 jan/02/1970 00:02:05
15 4.5/mpls-4.5-p... package 246301 jan/02/1970 00:02:05
16 4.5/multicast-... package 234144 jan/02/1970 00:02:06
17 4.5/ntp-4.5-pp... package 150171 jan/02/1970 00:02:06
[admin@MikroTik] > system package print
Flags: X - disabled
NAME VERSION SCHEDULED
0 routeros-powerpc 4.2
1 system 4.2
2 wireless 4.2
3 routerboard 4.2
4 hotspot 4.2
5 X ipv6 4.2
6 advanced-tools 4.2
7 mpls 4.2
8 security 4.2
9 routing 4.2
10 ppp 4.2
11 dhcp 4.2
[admin@MikroTik] >
is there something i have to do for upgrade correctly .
Did you reboot with ‘system reboot’ or just remove power and power back up?
I upgraded a pair of RB800s with the PPC combined pacage without problems.
Tom
Hi
i did through system–reboot , i also after that when its not upgraded turn it power off and on and both are same ..
but the package i download it is " All packages " not the combined packages .. is this affect ?
Regards
Does the log says anything like “broken package”?
yes, in ‘/log print’ you will see the reason
You only need to upload routeros-powerpc-4.5.npk and then reboot.
if that a Folder I see?
RouterOS doesn’t support folders
upload all NPK files to the root level of the file tree.
Thanks , i did and its succefully upgraded .
