Hi, I have this vlans configuration on a mikrotik router ( not switch ). Why does the computer connected to port vlan10-eth1 not see the computer in vlan10-eth2 and ping to address 192.168.10.2 does not work ?
Computers with vlan-id=10 are connected to ports vlan10-eth1 and vlan10-eth2.
to answer your question:
ARP ← without layer 2 there is no layer 3 / simple logic
If you want answers provide more complete information starting with
/export file=anynameyouwish (minus router serial number, any public WANIP information, keys etc.)
THe config is interrelated showing what you thing we need to see is NOT helpful.
By the way, a bridge is not absolutely required but its kinda how the ROS was designed to work most efficiently.
Once the config is shown, an optimal config based on your requirements can be designed.
that’s not what I mean. The question is why the microtik does not forward traffic between eth1 and eth2 port
i must use 192.168.10.0 network but without bridge. is it possible ?
Before anything else, if you check your configuration, you will find several instances of * (asterisk) followed by a (hex) number.
This basically means that there was something there that was renamed/deleted/moved/changed in such a way that the RoS can’t find it properly anymore, so it places there a sort of placeholder.
bridge *13 and *17, interface *14, etc. in the best case do nothing, in the worse they prevent the switching or routing.
You need to correct them before going on.
You’ve set 192.168.10.1/24 to one interface and 192.168.10.2/24 to the other interface. Every normal device will assume these two addresses are in same subnet and hence directly accessible without explicitly using router. And bridge is here to pass traffic from ether1 to ether2 (with appropriate VLAN headers attached).
If you want to force devices, connected to ether1, to use router when talking to devices, connected to ether2, then you have to make two distinct IP networks as already suggested by @panisk0
I’m feeling a XY problem here … so why don’t you explain the task you want to do in plain English words without thinking of ROS configuration.
