problem with VLAN connectivity
hi,
i have a RB711-5Hn-M Ethernet port connected to a VLAN with the IP 10.4.2.245/24
i can ping the corresponding gateway 10.4.2.1
but when i try to ping other VLAN gateway’s or IP in those VLAN i get error ROUTE not found.
parallel i have my laptop connected in the same way with IP 10.4.2.243/24
i can ping the corresponding gateway 10.4.2.1 and also other VLAN gateway’s and IP Addresses.
why does the routerboard fail to ping other VLAN’s???
are the other gateways in the same subnet (10.4.2.0/24)? If not you need to add the corresponding route (or the default route). Maybe you need to describe your VLAN/interface/ip address schema…
yes…all VLAN’s are in the same (/24) subnet…
please help :slight_smile:
“all the VLANs are in the same subnet” - it sounds crazy for me. Either I am too tired now or you have something strange in the network schema. If we are talking about routing then IMHO you cannot have one subnet split into multiple VLANs. You can only split the bigger subnet into smaller ones and assign them to VLANs (i.e. to interface attached to a VLAN).
And if you have multiple VLANs in a bridge it is not usually good thing too.
confusing :slight_smile: i knew there was some issue in their LAN
thanks anyways…
