Hi everyone,
I’m new to MikroTik and RouterOS.
I will have ton configure a MikroTik router CCR1036-12G for my work and wanted to practise with GNS3 for learning commands and conf.
What I’m trying to do is basic configuration, one router, one switch and two PC.
PC1 is configured with IP 10.0.10.1/24
PC2 is configured with IP 10.0.20.1/24
Mirkotik router is configured like that:
Interface connected on the switch: ether4
VLAN interface VLAN10 linked to ether4
VLAN interface VLAN20 linked to ether4
IP for interface VLAN10: 10.0.10.254/24
IP for interface VLAN20: 10.0.20.254/24
Basic Switch from GNS3 is configured like that:
Port1: Mode Access, VLAN ID:10
Port2: Mode Access, VLAN ID:20
Port8: Mode Dot1Q (TRUNK)
When i’m trying to do a ping between PC2 and Router, i have no answer, but with WireShark, I can see that the ARP request is propaging on wire between Switch and Router, with VLAN ID:
And on wire between PC2 and Switch it’s untagged:
Looks like Router is not responding to ARP
If I try a ping from router to PC2, with WireShark, I can see that PC2 is answering to ARP:
But still no pinging, looks like Router is not receiving and interpreting ARP answer…
I’ve tryied to add manually MAC for PC2 in ARP table:
but it’s going very strange, WireShark says request AND reply, so it seems to be working, but Router says Timeout…
The same for PC1 and VLAN ID 10.
What I’m missing?
I’ve tryied a lot of configurations, with bridge for example, still the same…
Is there a problem with my conf, it’s a bug from GNS3 or i’ve missunderstanding how VLANs and Trunk are working in RouterOS?
Maybe it’s because i didn’t have any license installed, but i’ve tryied with free license (limited to 1 VLAN per interface), the same…
Thanks for helping
Regards.
