Problem with VoIP quality. PhoneJack
I have a problem with voice quality.
I am using PhoneJack phone card, but I do not understeand the card parameters a their values. Who can tell me what is the best values with brief description ?
playback-volume=0
record-volume=0
agc-on-playback=yes
agc-on-record=yes
aec=yes
aec-tail-length=short
aec-nlp-threshold=low
aec-attenuation-scaling=4
aec-attenuation-boost=0
software-aec=yes
Did you try looking in the manual? :wink:
http://www.mikrotik.com/docs/ros/2.8/ip/telephony.content#7.45.5
Yes I have read, but do you have an experience what is the best values ?
It should work with default values. What setup do you have? ..maybe problem is not in PhoneJack..
Anyway.. try to turn off agc-on-playback and agc-on-record, play with record-volume and playback-volume
I would like to disscus with you a problem with interruptions which I have during the voice calls.
so give some more information about your setup! From where (PhoneJack I suppose) to where (VoIP? Voicetronix? ISDN?) you are trying to call and so on.
I’m not a telepathist you know… :wink:
I have five routers as follows:
A. 64 kbps - Frame Relay - PhoneJack - PBX
B. 64 kbps - Frame Relay - PhoneJack - PBX
C. 64 kbps - Frame Relay - PhoneJack - PBX
D. 64 kbps - Frame Relay - PhoneJack - PBX
E. 512 kbps - Ethernet - Voicetronix - PBX
During conversation from all of them I have interruption to router E.
Router A (B,C,D) mangle:
0 src-address=192.168.4.0/24 in-interface=ether2 action=accept
mark-flow=data set-tos=224
1 src-address=192.168.10.18/32 dst-address=192.168.0.0/20 action=passthrough
mark-flow=voice set-tos=96
Router A (B,C,D) queue tree:
0 name="data" parent=KK-Ruse flow=data limit-at=0 queue=synchronous-default
priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0
1 name="voice" parent=KK-Ruse flow=voice limit-at=64000
queue=synchronous-default priority=1 max-limit=64000 burst-limit=0
2 name="KK-Ruse" parent=pvc1 flow="" limit-at=64000
queue=synchronous-default priority=8 max-limit=64000 burst-limit=0
Router E mangle:
0 src-address=192.168.0.0/24 in-interface=ether3 action=accept
1 src-address=192.168.10.5/32 dst-address=192.168.0.0/20 connection=!data
action=passthrough mark-flow=voice set-tos=96
Router E queue tree:
0 name="KK-Baza" parent=ether2 flow="" limit-at=512000
queue=synchronous-default priority=8 max-limit=512000 burst-limit=0
1 name="data" parent=KK-Baza flow=data limit-at=320000
queue=synchronous-default priority=8 max-limit=320000 burst-limit=0
2 name="voice" parent=KK-Baza flow=voice limit-at=320000
queue=synchronous-default priority=1 max-limit=512000 burst-limit=0
Phonejack configurations:
0 name="phonejack-pci1" autodial="" region=us
ring-cadence="++-++--- ++-++---" playback-volume=6 record-volume=4
agc-on-playback=yes agc-on-record=yes aec=yes aec-tail-length=short
aec-nlp-threshold=low aec-attenuation-scaling=4 aec-attenuation-boost=0
software-aec=yes
Voicetronix configuration:
0 name="vctx1" autodial="" region=us playback-volume=5 record-volume=4
agc-on-playback=yes agc-on-record=yes detect-cpt=no
loop-drop-detection=no balance-registers=200 balance-status="-1.87dB"
1 name="vctx2" autodial="" region=us playback-volume=10 record-volume=4
agc-on-playback=yes agc-on-record=yes detect-cpt=yes
loop-drop-detection=no balance-registers=200 balance-status="-2.15dB"
2 name="vctx3" autodial="" region=us playback-volume=6 record-volume=3
loop-drop-detection=no balance-registers=200 balance-status="-1.99dB"
3 name="vctx4" autodial="" region=us playback-volume=6 record-volume=4
loop-drop-detection=no balance-registers=200 balance-status="-1.80dB"
Please if you need more information let me know.
Kamen
Do you have interruptions with all queues disabled?
so you are calling TO router E or through it (to PSTN)?
Yes.
I have to use queues, because I have voice and data.
How quality is going to improve If I disable queues ?
For example:
Call from A TO E:
PBX-PhoneJack-MT-FrameRelay - MPLS Core Network - Ethernet-MT-Voicetronix-PBX
you’ll see if your queues affect the quality.. if not then the problem is not in queues
PBX is connected to PhoneJack??
PhoneJack is FXS interface – this means that only telephone device can be connected to it!
I use external line from PBX, so it is the same as telephone.
thats ok
so, what about queues?
and what is your pbx regional settings? you have region=us on PhoneJacks and Voicetronix… try to change this parameter
The PBX’s are Panasonic KDX-100, but MT there is no options for my region in Bulgaria.
I will try the voice quality w/o queues.
Try germany
You can also try other codecs from /ip telephony codecs – simply disable those you don’t want to use (for example 711 – they use much bandwidth). You can see what codecs you use monitoring an interface while speaking.
What is the difference between playback-volume and record-volume parameters ?
playback is what you hear (a card plays to the port) and record is what you say (a card is receiving signal)
When I adjusted playback-volume and record-volume the rsult was bette voice quality, so the problem was not in queues.
