If i use no Authentication everything works like it should. If i use “simple” authentication everything works like it should. If i use “ah” authentication with a 16-char long password there is a messup: Router 1 AND Router 3 are taking the mastership.
Hi!
Since a VRRP multi-cast does not leave it’s own broadcast domain (unless you are routing multicasts (but even still you shouldn’t be routing VRRP multicasts)) why do you need authentication? I’m not trying to bypass your question about a bug (I’ve encountered a few with VRRP (ok.. maybe not bugs but more like erratic behaviour)), just wondering why authentication is necessary.
