Problem with winbox.
I’m having problems accessing the router through winbox. I have configured a ip for port ethern3, and it is set to active. I have changed the network card to use a manual ip with in the range of the router. However I do not find the router when using the windbox software. What am I doing wrong?
Rkvikstad
  1. Make sure Windows firewall does not block Winbox application.
  2. Try to type IP address (MAC-address) of the router manually to “Connect To” window of Winbox.
Thank you for your answer, I get a message stating " could not connect to “bla bla bla” (port 20561) - timed out!
can you ping the same IP from the Windows computer you are using?
