Problem with wireguard
Hi!
I’m trying to configure wireguard vpn on my mikroitk. But when I try to connect from 2 and more peer. I have trouble with connections. I can see successful handshake, but internet still works only on first connection peer.
# 2023-08-30 16:00:04 by RouterOS 7.12beta3
# software id = YL68-7YYE
# model = RB2011UiAS-2HnD
# serial number = 7A67082B91C6
add admin-mac=CC:2D:E0:14:EE:09 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=60:31:97:3C:9E:64
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk mode=dynamic-keys name=profile1 \
    supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge security-profile=profile1 ssid=Viteb_House wireless-protocol=\
    802.11
add name=dhcp ranges=192.168.0.10-192.168.0.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
/interface wireguard peers
add allowed-address=0.0.0.0/0 comment="iphone Andrey" interface=wireguard1 \
    persistent-keepalive=10s public-key=\
    "W0RmYW0PMfYB377mrUi4w2Q+pwfiFklne3FEmQDmRhg="
add allowed-address=0.0.0.0/0 interface=wireguard1 persistent-keepalive=10s \
    public-key="xhXxO1ZUU9agbVi+f8D0kIimAUQysQSpauK7zZEXUxQ="
    public-key="foiAlsF0diVTNmG7CMOmZxtJNvMiQC4fKikxeCram1Y="
    public-key="iSciqNSlIyI1/SrU+reXRusnp7xpnT+RStlBdYjYokY="
add allowed-address=0.0.0.0/0 comment="xiaomi andrey" interface=wireguard1 \
    "EYhX8ib7yjuY1zLYcKmic0oHEfy0VIyjIeBmLj1d0AU="
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
    192.168.0.0
add address=174.16.0.1/24 interface=wireguard1 network=174.16.0.0
add address=174.16.1.1/24 interface=wireguard1 network=174.16.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.1 gateway=\
    192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
    established,related,untracked
add action=accept chain=input comment="winbox internet" dst-port=8291 \
    protocol=tcp
add action=accept chain=input comment=wireguard dst-port=13231 \
    in-interface-list=WAN protocol=udp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Moscow
/system note
set show-at-login=no
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
And additional question. How use new command wg-add-client, I cant understand what need write in this fields .
/interface/wireguard/wg-add-client
client-address:
endpoint-address:
number:
You cannot have multiple peers and use an allowed IP of 0.0.0.0/0 on the router. This is why the first connected client works but the others don’t. The router is being told to send ALL traffic to the peer (the first connected) and so it all goes to peer1 and to no one else. Instead you need to set the allowed IP for each peer to the wireguard IPs that are assigned to each client. Then on your client set the allowed IP to 0.0.0/0. Of course on the router side you need to make sure your firewall and NAT rules allow traffic to flow as you desire.
Assuming your MT Router acts as the server for the handshake and you have remote users coming in as clients, then your config is, as noted, in error.
Each wireguard client device (aka remote user) should have on THEIR settings for peer settings.
a. 0.0.0.0/0 if they plan on going out the internet and possibly reach LAN devices and possibly configure router (depends upon firewall rules)
b. LANSUBNET if they plan on only going to LAN devices
c. WIREGUARD Subnet if only for admin to configure router.
Also client devices on their peer setting need keep alive settings.
The router peer settings should be the wireguard address of the client devices ip/32
NO requirement for keep alive on router.
Gabacho pointed out the importance of how ALLOWED IPs works in the wireguard process.
lite reading here: https://forum.mikrotik.com/viewtopic.php?t=182340
corrected it to:
add allowed-address=174.16.0.3/32 comment="iphone Andrey" interface=\
    wireguard1 persistent-keepalive=10s public-key=\
add allowed-address=174.16.0.105/32 comment="Notebook Misha" interface=\
add allowed-address=174.16.0.106/32 comment="TV Xiaomi " interface=wireguard1 \
add allowed-address=174.16.0.104/32 comment="iphone Misha" interface=\
add allowed-address=174.16.0.4/32 comment="xiaomi andrey" interface=\
And It’s work Thanks.
I fixed only on router and nothing on client.
What about new command? (wg-add-client)
what the number?
You didnt read my post…
You DONT NEED KEEP ALIVE on the router settings, its a setting for your mobile users on their peer settings.
I changed it before, it was previous config.
