Hello everyone.
I am trying to configure CAPsMAN with three CAPs, the main device is MIKROTIK L009UIGS-2HAXD-IN 2.4 GHz, as the CAPs I am trying to use “cAP XL ax”, “Groove 52” and “RBCAPL-2ND 2.4 GHz” devices. Configuring of CAPsMAN service goes fine, the devices are visible and it seems working corectly. There are two WiFi sites with separated VLAN:
- main WiFi, for normal users, with user-to-user forwarding, SSID: MAIN
- guests WiFi, for outside clients, which is spearate from main WiFi, SSID: GUEST
And the problem is that, only the GUST site offered acces to the internet. The deives which connects to the MAIN site can not get the acces to the internet. The MAIN site and ethernet ports are working on the same bride - devices connected to the ethenet port can be connected to the intenet, the wireless devices connected to the MAIN site not. There is also the DHCP problem, because devices connected to the MAIN site are getting wrong IP adresses (outside the definied pool).
There is the config from CAPsMAN, does everyone can find the bug, that is the cause of my problem? Thank you.
# 2024-11-11 21:46:28 by RouterOS 7.16.1
# software id = QQQQ-QCL5
# model = L009UiGS-2HaxD
# serial number = HGG09NDQMDE
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=XX \
frequency=2412 name=channel1
frequency=2437 name=channel6
frequency=2462 name=channel11
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=XXXX \
frequency=5180 name=channel36
frequency=5200 name=channel40
add name=GUEST-LAN vlan-filtering=yes
add name=LAN vlan-filtering=yes
set [ find default-name=ether8 ] poe-out=forced-on
/interface vlan
add interface=GUEST-LAN name=VLAN-GUEST vlan-id=20
add interface=LAN name=VLAN-LAN vlan-id=10
/caps-man datapath
add bridge=LAN client-to-client-forwarding=yes name=main vlan-id=10 \
vlan-mode=use-tag
add bridge=GUEST-LAN client-to-client-forwarding=no name=guest vlan-id=20 \
vlan-mode=use-tag
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm,tkip \
group-encryption=aes-ccm name=guest
group-encryption=aes-ccm name=main
/caps-man configuration
add channel=channel6 channel.band=2ghz-b/g/n country=poland datapath=main \
datapath.bridge=LAN .vlan-id=10 .vlan-mode=use-tag name=cfg_dom-2ghz \
security=main ssid=MAIN
add channel=channel40 channel.band=5ghz-a/n/ac country=poland datapath=guest \
datapath.bridge=GUEST-LAN .vlan-id=20 .vlan-mode=use-tag name=\
cfg_guest-5ghz security=guest ssid="GUST"
add channel=channel6 channel.band=2ghz-b/g/n country=poland datapath=guest \
cfg_guest-2ghz security=guest ssid="GUST"
datapath.bridge=LAN .vlan-id=10 .vlan-mode=use-tag hide-ssid=yes name=\
cfg_dom-2ghz-hidden security=main ssid=MAIN
add channel=channel40 channel.band=5ghz-a/n/ac country=poland datapath=main \
datapath.bridge=LAN .vlan-id=10 .vlan-mode=use-tag name=cfg_dom-5ghz \
/caps-man interface
add configuration=cfg_dom-2ghz disabled=no l2mtu=1600 mac-address=\
DC:2C:6E:1E:45:2C master-interface=none name=cap5 radio-mac=\
DC:2C:6E:1E:45:2C radio-name=DC2C6E1E452C
add configuration=cfg_dom-5ghz disabled=no l2mtu=1600 mac-address=\
DC:2C:6E:1E:45:2D master-interface=none name=cap6 radio-mac=\
DC:2C:6E:1E:45:2D radio-name=DC2C6E1E452D
add configuration=cfg_guest-2ghz disabled=no l2mtu=1600 mac-address=\
DE:2C:6E:1E:45:2C master-interface=cap5 name=cap7 radio-mac=\
00:00:00:00:00:00 radio-name=""
add configuration=cfg_guest-5ghz disabled=no l2mtu=1600 mac-address=\
DE:2C:6E:1E:45:2D master-interface=cap6 name=cap8 radio-mac=\
add name=WAN
add name=guest_dhcp_pool ranges=192.168.3.2-192.168.3.254
add name=dhcp_pool ranges=192.168.1.2-192.168.1.254
add address-pool=guest_dhcp_pool interface=VLAN-GUEST name=guest_dhcp
add address-pool=dhcp_pool interface=LAN name=lan_dhcp
/port
set 0 name=serial0
/caps-man manager
set enabled=yes
/caps-man manager interface
add interface=LAN
/caps-man provisioning
add action=create-dynamic-enabled identity-regexp=PIETRO \
master-configuration=cfg_dom-2ghz radio-mac=DC:2C:6E:1E:45:2C \
slave-configurations=cfg_guest-2ghz
add action=create-dynamic-enabled identity-regexp="PIETRO " \
master-configuration=cfg_dom-5ghz radio-mac=DC:2C:6E:1E:45:2D \
slave-configurations=cfg_guest-5ghz
add action=create-dynamic-enabled identity-regexp=OGROD master-configuration=\
cfg_dom-2ghz-hidden slave-configurations=cfg_guest-2ghz
add action=create-dynamic-enabled identity-regexp=MALY master-configuration=\
cfg_dom-2ghz slave-configurations=cfg_guest-2ghz
add bridge=LAN interface=ether2
add bridge=LAN interface=ether3
add bridge=LAN interface=ether4
add bridge=LAN interface=ether5
add bridge=LAN interface=ether6
add bridge=LAN interface=ether7
add bridge=LAN interface=ether8
add bridge=*11 interface=ether1
/interface bridge vlan
add bridge=LAN vlan-ids=10
add bridge=GUEST-LAN vlan-ids=20
add interface=ether1 list=WAN
add interface=LAN list=*FFFFFFFF
add address=192.168.3.1/24 interface=VLAN-GUEST network=192.168.3.0
add address=192.168.1.1/24 interface=LAN network=192.168.1.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.2 comment=PIETRO mac-address=DC:2C:6E:1E:45:2A
add address=192.168.1.3 comment=OGROD mac-address=78:9A:18:DF:83:D7
add address=192.168.1.4 comment=MALY mac-address=F4:1E:57:37:AE:12
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 \
netmask=24
add address=192.168.3.0/24 dns-server=192.168.3.1 gateway=192.168.3.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=accept chain=forward out-interface=ether1 src-address=\
192.168.1.0/24
192.168.3.0/24
add action=drop chain=forward disabled=yes dst-address=192.168.1.0/24 \
src-address=192.168.3.0/24
add action=drop chain=input disabled=yes src-address=192.168.3.0/24
add action=drop chain=forward disabled=yes dst-address=192.168.3.0/24 \
src-address=192.168.1.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=\
192.168.1.0/24
192.168.3.0/24
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=ROUTER
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
