Problem with wlan
Hello!
I am new with Mikrotik, still learning. I would like to ask some help. I bought a hap ac2 to home, set up but something is not good with wlan. Tried with qos and without it too. I tested with 2 mobile phone 2,4 ghz. When i download with one on full speed, meanwhile upload with full speed on the other. The upload speed is very slow. With qos was the same, when i started speedtest the same time, one goes full speed, the other one failed. I've just reset the configuration, so the firewall and others not finished yet. Can somebody help me? Thanks
mar/21/2021 20:30:56 by RouterOS 6.48.1
software id = F5ZG-LZKU
model = RBD52G-5HacD2HnD
serial number = C6140D7235F1
add name=bridge1
add name=bridge2_2,4
add name=bridge3_5
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=1
max-mru=1410 max-mtu=1410 name=pppoe-out1 password=****** user=
md
add name=LAN
add name=WAN
add name=WLAN
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=wlan
supplicant-identity=MikroTik wpa2-pre-shared-key=
wlan_5 supplicant-identity=MikroTik wpa2-pre-shared-key=********************
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX
country=hungary default-forwarding=no disabled=no frequency=2427
installation=indoor mode=ap-bridge security-profile=wlan ssid=
MikroTik_MOD wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-XXXX
country=hungary default-forwarding=no disabled=no frequency=5200
installation=indoor mode=ap-bridge security-profile=wlan_5 ssid=
MikroTik_MOD_5 wps-mode=disabled
/ip hotspot profile
add name=lan ranges=192.168.10.100-192.168.10.200
add name=wlan ranges=192.168.11.100-192.168.11.200
add name=wlan_5 ranges=192.168.12.100-192.168.12.200
add address-pool=lan disabled=no interface=bridge1 lease-time=12h name=lan
add address-pool=wlan disabled=no interface=bridge2_2,4 lease-time=12h name=
wlan
add address-pool=wlan_5 disabled=no interface=bridge3_5 lease-time=12h name=
wlan_5
/queue simple
add dst=pppoe-out1 max-limit=1G/1G name=digi queue=
pcq-upload-default/pcq-download-default target=""
add dst=pppoe-out1 max-limit=1G/1G name=lan parent=digi queue=
pcq-upload-default/pcq-download-default target=192.168.10.0/24
add dst=pppoe-out1 max-limit=100M/100M name=wlan parent=digi priority=1/1
queue=pcq-upload-default/pcq-download-default target=192.168.11.0/24
add dst=pppoe-out1 max-limit=300M/300M name=wlan_5 parent=digi priority=1/1
queue=pcq-upload-default/pcq-download-default target=192.168.12.0/24
add bridge=bridge2_2,4 interface=wlan1
add bridge=bridge3_5 interface=wlan2
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes
/ip settings
add interface=bridge2_2,4 list=LAN
add interface=bridge3_5 list=LAN
add interface=ether1 list=WAN
add address=192.168.10.1/24 interface=bridge1 network=192.168.10.0
add address=192.168.11.1/24 interface=bridge2_2,4 network=192.168.11.0
add address=192.168.12.1/24 interface=bridge3_5 network=192.168.12.0
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
netmask=24
add address=192.168.11.0/24 dns-server=192.168.11.1 gateway=192.168.11.1
netmask=24
add address=192.168.12.0/24 dns-server=192.168.12.1 gateway=192.168.12.1
netmask=24
set allow-remote-requests=yes servers=127.0.0.1,1.1.1.1,8.8.8.8
add action=masquerade chain=srcnat src-address=192.168.10.0/24
add action=masquerade chain=srcnat src-address=192.168.12.0/24
add action=masquerade chain=srcnat src-address=192.168.11.0/24
/system clock
set time-zone-name=Europe/Budapest
/system identity
set name=MikroTik_MOD
Yeah, your config needs rework for sure.
For starters only need one bridge.
Nothing wrong with multiple subnets!
Firewall rules need serious help.
To much funky stuff for mangling there not required
Masquerade nat rules not right.
and more…
Recommend go back to default settings.
Dont change anything from that with regard to firewall rules nat etc…
ensure both the etherport and the PPOE-connection interfaces are list members on the WAN.
Keep one bridge.
Should be at a much better starting point to troubleshoot wifi.
Thanks, i was f*cking angry and i create this config only few minutes. The point is, with default settings, wlan is useless.
Yes, one still has to program the wifi settings but that is trivial
compared to setting up the router properly for interfaces such as subnets and vlans ( i prefer vlans)
and then the bridge and bridge port settings (and bridge vlan setting is using vlans).
Firewall rules need minimum change.
Then setup wifi.
Should start with a single subnet and SSID.
Just to get the basics.
Then expand into more complex things one at a time.
You need a reference of your link quality to say that Wifi is really bad and not your link.
Have you done speedtest via ethernet in both directions? What is the speed you see?
Mikrotik is in 2.4Ghz as good as any other device. And this band is pretty much useless in crowded environment.
So perf. problems are mainly due to other factors (interference etc.) than Mikrotik device.
Its a different story for 5Ghz, but this is not where you have the problem you say.
What is the distance between you and the AP when you do the wifi tests? What are the speeds you get?
If you use a low end phone with 1x1 11a support only you can not expect anything outstanding :wink:
I disagree with this.
Mikrotik shutting off wireless entirely when the 2.4 radio is crowded is CONSIDERABLY WORSE, than my other vendor. Which slows way down but still gets a connection.
