i want set uptime for users that server=all and profile=512
ip hotspot user set limit-uptime=35:00:00 [find server =all & profile =512]
but not work correct.
/ip hotspot user set limit-uptime=35:00:00 [/ip hotspot user find server=all && profile=512]
& is a bitwise OR, && is a boolean OR. You mustn’t have spaces between key/value pairs. Also, sub-commands (commands in pairs) don’t inherit the scope, so you have to change into the “/ip hotspot user” context for the find operation. Alternatively, you can scope the entire thing:
/ip hotspot user {
set limit-uptime=35:00:00 [find server=all && profile=512]
Unfortunately does not work.
I didn’t pay enough attention fixing your original code, and the setter has the items and key/values in the wrong order.
/ip hotspot user set [/ip hotspot user find server=all && profile=512] limit-uptime=35:00:00
That works fine, as below:
[admin@corporate] /ip hotspot user> print detail where name=test
Flags: X - disabled, D - dynamic
9 name="test" password="test" profile=1m uptime=1d13h58m46s bytes-in=32075936 bytes-out=200606091 packets-in=178406 packets-out=241941
[admin@corporate] /ip hotspot user> set [find name=test && profile=1m] limit-uptime=35:00:00
9 name="test" password="test" profile=1m limit-uptime=1d11h uptime=1d13h58m46s bytes-in=32075936 bytes-out=200606091 packets-in=178406 packets-out=241941
