I got a rb911 lite 5 hnd routerboard and im looking to use it as a wifi repeater but when i try to login using winbox it shows next to the mac adress that the ip is 0.0.0.0 if i login using the mac adress it says loggin in forever. and if i type in 192.168.88.1 it says couldnt connect to 192.168.88.1
If anyone knows whats the problem plz reply.
try other ethernet port…
Reset to factory defaults or click on the MAC address in Winbox rather than the IP.
