problem
i have a problem with my mikrotik cloud core 1036 how and i tried to reset it with the reset button and jumber how can i reset it’s OS plz help
Can you access your router by using winbox? if you can access by using winbox then apply bellow command.
loggin in to router by using winbox
open “new terminal”
/system reset-configuration
type yes
it will reset your router to factory default.
