Probleme configuring VLAN
Hi there
I got recently a CRS 125 cloud router switch and used it only as a switch for now. I need to connect a device on a particular VLAN port in order to “isolate” it from my regular lan network (I don’t want this device to see my lan, the device itself is an android mediaplayer from my isp). I can’t change the network configuration of the device itself (no vlan settings, only ip settings), so I would like the device to communicate on a choosen vlan affected to an CRS125’s port. In fact, I want anything that connect to this port use by default the configured VLAN.
On the switch port 1, I also have the LAN zone of an Opnsense firewall machine. There, I’ve configured a VLAN 100 interface which provide DHCP service to a VLAN 100 network. I’ve tried many settings on the CRS, but I’havent managed to have them talk to each other. (I’m sure that the opnsense config is ok, I’ve connected a computer with VLAN 100 affected to the network card and got the right ip and proper connection). I currently use RouterOS 6.41.3 with default config (just changed the IP)
Any help very appreciated
