probleme of browsing via mikrotik router
i esplain again very well my probleme
my mikrotik router was configure;on my mikrotik router i was able to ping http://www.yahoo.fr .
i was able to make traceroute to http://www.yahoo.fr
i was able to ping my DNS
but in my mikrotik router is commande line and have two network cart
one connect in public network and another owne in local network.
i connect a host in a loca netwok . in that host connect in local network in was able to browsing in internet.
but in ping the local interface of mikrotik
i ping public interface of micritk
i think the explication is very clear
i need a help
I think you can add reply to the previous topic, as you have the same topic as previous post.
Thank you for the description, but you have not metntioned here about current problems.
current problems.[/quote]
the probleme is that as the Mirotik is configure ar a router i must connect the interface public in inetrnet and connect the interface local in a host
in that host in private network i was not able to browsing in internet
this is the result of command
erminal vt102 detected, using multiline input mode
[admin@MikroTik] > ip firewall nat
[admin@MikroTik] ip firewall nat> print
0 chain=srcnat action=masquerade out-interface=public action=accept
I think you need to remove the action=accept from your rule unless i’m thinking of something else,i don’t use nat in mt often
0 chain=srcnat out-interface=public action=masquerade
How do you get NAT rule with two action specified ?
