good, can someone help me? Since yesterday morning I have been trying to access a hAP lite router that I had to update, the thing is that I update from the winbox interface and since then every 2 or 3 min all the lights turn on and then turn off and so on and since then Can not access through the netinstall either, can someone give me a solution?
try netinstall to update a device i suspect it’s brick due to previous attempt to update firmware, just disable all network interface in your computer except the LAN Ethernet before running netinstall the wiki is very clear on this try that and netinstall will work for you!
I’m going to try the idea, by chance where can I get a version of the operating system?
if you are using hap lite this is it https://download.mikrotik.com/routeros/6.48.2/routeros-smips-6.48.2.npk
You might also try netinstall with a different power supply for the hAP lite. It may not be providing the proper power needed for boot up.
do you think that is? The truth is, because of my work and others I have not been able to provide maintenance so I think today I am going to do it
