i’ve just configured a RB750r2 as rooter wit nat.
Everthing works fine, as long as Clients configured to use use DHCP server of router.
But when i configure a fix ip at client side (IP-Adress, Gatway), client is able to communicate, but is not able to access DNS Server.
This is very strange, because the manually configured ip is not in use and also outside of DHCP range.
I tried to also define explicit DNS Server at client side as 8.8.8.8 and also as the router ip gateway itself - which is also used when a client is using DHCP - but both has not helped.
Dose somene has an idea what is causing this strange beaviour and how to solve it ?
I can’t imagine, that there is a different between an ip adesss received by DHCP server and one manually configured at client side. So does someone out here has an explanation for this behaviour ?
I need to use a fixed ip adress for my NAS.
Without seeing the rest of your config and the config on the host itself, we simply don’t know. What you can do is allow the DHCP to assign an IP and then go in “right click” then select “make static.” This will ensure your host device gets the same IP every time.
