Problems accessing VPN
Good Morning. I’m new in this forum and I’m new with Mikrotik.
I’m trying to access to my network from internet configuring a VPN with Microtik hAP Lite. I have a dynamic public IP.
Mi configuration is: ISP Router → Mikrotik → LAN
I’ve tried with VPN + DDNS, VPN PPTP and L2TP/IPsec. I need to use the IP Cloud DNS Name provided for Mikrotik because of the dynamic public IP.
When i’m connected to the same network of the Mikrotik and I use the IP that the ISP Router provides to the Mikrotik, the VPN works well.
But when I try to connect from internet using the IP Cloud DNS It does’nt work. I also tried it with the public IP but it didn’t work either
I’ve forwarded ports in the ISP Router: 1723, 8291, 500, 1702, 80, 15252 and 4500. All udp and tcp.
I hope you can hepl me.
Thanks in advance
Rodolfo
