Is there a comprehensive walkthrough somewhere on setting up the Routerboard hAP ac to work with the Groove ac?
With my previous router this seemed simple, but i’m having problems with the hAP ac. Especially when it comes to setting eth5 as the WAN port to make use of PoE.
I’m finding that RouterOs is constantly crashing when I change various settings. When I set eth5 master to none, and set DCHP to eth5, in the quick settings sceen, I only have the option of selecting eth1 or spf1 as the source for the WAN connection.
The basic setup I’m trying to achieve is to use the Groove ac to pick up wifi, then access that through the Routerboard, with all devices laptops, mobiles etc.. only connecting to the Routerboard.
Any help would be greatly appreciated.
