I’m trying to build a PTP network with an external DHCP server. Master has the DHCP server (with internet) on the ethernetport, and client has the “client” network on the ethernet port. Everything seems to work with the wireless connection, the slave Mikrotik gets an IP adres, but when I connect something on the ethernetport of the slave, no IP address is assigned, so no internet.
Below the two configs:
Master:
# aug/08/2020 22:13:12 by RouterOS 6.45.8
# software id = KTYY-UZN9
# model = RBLHGG-5acD
# serial number = 99F30CAE42BD
add name=BridgeStraal
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=25 country=netherlands disabled=\
no mode=bridge nv2-preshared-key=Password nv2-security=enabled ssid=\
Straal wireless-protocol=nv2
/interface wireless nstreme
set wlan1 enable-nstreme=yes
add bridge=BridgeStraal interface=wlan1
add bridge=BridgeStraal interface=ether1
/interface bridge vlan
add bridge=BridgeStraal vlan-ids=1
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=BridgeStraal
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=Thuis
/tool romon
set enabled=yes secrets=Password
Slave:
# aug/08/2020 22:17:44 by RouterOS 6.44.5
# software id = 2RG7-HYBC
# model = RouterBOARD LHG G-5acD
# serial number = 99F30B29A650
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=25 disabled=no mode=\
station-pseudobridge nv2-preshared-key=Password nv2-security=enabled \
ssid=Straal wireless-protocol=nv2
add name=WAN
add name=LAN
/ip hotspot profile
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
/ip dhcp-client
/system clock
/system identity
set name=Zaak
/tool romon
What goes wrong?
