gxmc
June 3, 2014, 11:11am
1
Steam’s page says the following:
Steam Client
UDP 27000 to 27015 inclusive (Game client traffic)
UDP 27015 to 27030 inclusive (Typically Matchmaking and HLTV)
TCP 27014 to 27050 inclusive (Steam downloads)
UDP 4380
Then I did the following rules
14 chain=dstnat action=dst-nat to-addresses=192.168.75.10 protocol=udp
dst-port=27000-27030
15 chain=dstnat action=dst-nat to-addresses=192.168.75.10 protocol=tcp
dst-port=27014-27050
16 chain=dstnat action=dst-nat to-addresses=192.168.75.10 protocol=udp
dst-port=4380
I tested them with the PortForward’s PortChecker tool and everything is fine but the Steam stops logging in when the rule 14 is active. Its one of those 30 UDP ports, I dunno which one but I guess it doesn’t matter. I need to know the reason the Steam stops working when I redirect the ports and the redirecting is working properly according to the testing tool.
I use Steam for play
The username on steam are the same as here…
You do not need to open anything, do not do any, remove all your rule, are all wrong,
simply enable UPNP on Routerboard and configure it correctly
This is my UPNP config, I never have one game that not work with that:
/ip upnp
set allow-disable-external-interface=no enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=MATRIX type=internal
add disabled=no interface=pppoe-client type=external
MATRIX must be your local ethernet / bridge
pppoe-client your internet source.
gxmc:
Steam Client
UDP 4380
dst-port=4380
Add the dst-address or in-interface parameter to the rules, this could solve your issue.
Have you Steam and using it?
Honestly no but I assumed this is ‘normal’ natting.
With the rules given, all packets will be dst-natted, inbound and outbound. That’s why I thought about specifying in-interface could help.
gxmc
June 4, 2014, 2:35am
6
rextended:
/ip upnp
/ip upnp interfaces
I know how to activate the UPnP and I actually use it, I disabled it in order to test something that involves the manual port opening.
gxmc
June 4, 2014, 2:46am
7
And it did, indicating the in-interface solved the problem, thanks.
Can you manage to explain it to me? I don’t understand why the Port Checker had no problems being reached by the outside and the Steam Client didn’t.
