Hi there!
I work at a school with different buildings and so far have we used Fortigate access points , but startet migrating til Mikrotik. We startet first with one building and around 15 cap ax, which worked great, but now with hundreds AP’s and thousands of clients we get some trouble.
The router and capsman run on a CCR2116-12G-4S+, 7.16.2 stable (I know it’s old firmware, it’s in my pipleline to upgrade “soon”).
The cap ax are on the same firmware version. The buildings are connected via single mode fiber 10GB, as switches use we Aruba 2930F and similar. I started with a better segmentation for a different complex and use there a Mikrotik CCR2004-16G-S2+. It should be soon a own capsman for that building.
Here is the config of one of the access points and router:
AP config
add frame-types=admit-only-vlan-tagged name=bridge1 vlan-filtering=yes
/interface wifi
managed by CAPsMAN
set [ find default-name=wifi1 ] configuration.manager=capsman datapath.bridge=bridge1
managed by CAPsMAN
set [ find default-name=wifi2 ] configuration.manager=capsman datapath.bridge=bridge1
/interface vlan
add interface=bridge1 name=vlan1000 vlan-id=1000
add name=management
add bridge=bridge1 interface=ether1 pvid=1000
add bridge=bridge1 interface=ether2 pvid=1000
set discover-interface-list=management protocol=lldp,mndp
/ip settings
set allow-fast-path=no ip-forward=no rp-filter=strict
/ipv6 settings
set forward=no
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether1,ether2 vlan-ids=100
add bridge=bridge1 tagged=bridge1,ether1,ether2 vlan-ids=110
add bridge=bridge1 tagged=bridge1,ether1,ether2 vlan-ids=120
add bridge=bridge1 tagged=bridge1 vlan-ids=1000
add interface=vlan1000 list=management
/interface wifi cap
set caps-man-addresses=10.10.10.1 discovery-interfaces="" enabled=yes
/ip cloud
set update-time=no
/system clock
set time-zone-autodetect=no time-zone-name=UTC
/system identity
set name=ap1xx
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=ntp.mydomain.com
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/ip dhcp-client
Here is the part of my router config:
Router config
/interface wifi channel
add disabled=no frequency=5170-5250,5250-5330,5490-5730 name=5GHZ width=20mhz
add disabled=no frequency=2402-2482 name=2GHZ width=20mhz
/interface wifi datapath
add disabled=no name=employee vlan-id=100
add disabled=no name=teacher vlan-id=110
add disabled=no name=student vlan-id=120
add disabled=no name=guest vlan-id=130
/interface wifi security
add authentication-types=wpa2-eap disabled=no eap-certificate-mode=verify-certificate ft=yes ft-over-ds=yes management-protection=allowed name=radius wps=disable
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes management-protection=allowed name=guest wps=disable
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes management-protection=allowed name=teacher wps=disable
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes management-protection=allowed name=student wps=disable
add authentication-types=wpa-psk comment=temporary disabled=no management-protection=allowed name=old-ipads wps=disable
/interface wifi configuration
add country=Denmark datapath=employee disabled=no name=employee security=radius security.ft=yes .ft-over-ds=yes ssid="Employee Notebooks"
add country=Denmark datapath=guest disabled=no name=guest security=guest security.ft=yes .ft-over-ds=yes ssid="Guest Wifi"
add comment="temporary ipad fix" country=Denmark datapath=guest disabled=no mode=ap name=old-ipads security=old-ipads ssid=old-ipads
add country=Denmark datapath=student disabled=no name=student security=student security.ft=yes .ft-over-ds=yes ssid="Student Wifi"
add country=Denmark datapath=teacher disabled=no name=teacher security=teacher security.ft=yes .ft-over-ds=yes ssid="Teacher Wifi"
/interface wifi access-list
add action=accept disabled=no interface=any signal-range=-76..0
add action=reject disabled=no interface=any signal-range=-120..-77
/interface wifi capsman
set enabled=yes package-path=/firmware require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment=library disabled=no identity-regexp="ap1(0[1-9]|2[0-7])" master-configuration=student name-format=%I-5g-wifi slave-configurations=guest,employee,teacher supported-bands=5ghz-ax
add action=create-dynamic-enabled comment=library disabled=no identity-regexp="ap1(0[1-9]|2[0-7])" master-configuration=employee name-format=%I-2g-wifi slave-configurations=guest,old-ipads supported-bands=2ghz-ax
add action=create-dynamic-enabled comment=building1 disabled=no identity-regexp="ap1(2[8-9]|3[0-9]|4[0-5])" master-configuration=student name-format=%I-5g-wifi slave-configurations=teacher,guest,employee supported-bands=5ghz-ax
add action=create-dynamic-enabled comment=building1 disabled=no identity-regexp="ap1(2[8-9]|3[0-9]|4[0-5])" master-configuration=old-ipads name-format=%I-2g-wifi slave-configurations=teacher,guest supported-bands=2ghz-ax
add action=create-dynamic-enabled comment=building2 disabled=no identity-regexp="ap1(4[6-9]|5[0-4])" master-configuration=employee name-format=%I-5g-wifi slave-configurations=guest supported-bands=5ghz-ax
add action=create-dynamic-enabled comment=building2 disabled=no identity-regexp="ap1(4[6-9]|5[0-4])" master-configuration=employee name-format=%I-2g-wifi slave-configurations=guest,old-ipads supported-bands=2ghz-ax
add action=create-dynamic-enabled comment=building3 disabled=no identity-regexp="ap1(5[5-9]|6[0-9]|7[0-9]|8[0-8])" master-configuration=employee name-format=%I-5g-wifi slave-configurations=guest,teacher,student supported-bands=5ghz-ax
add action=create-dynamic-enabled comment=building3 disabled=no identity-regexp="ap1(5[5-9]|6[0-9]|7[0-9]|8[0-8])" master-configuration=old-ipads name-format=%I-2g-wifi slave-configurations="" supported-bands=2ghz-ax
The problem is the following:
- The student ipads are connected to an AP, but sometimes they jump around to other AP’s. That happens frequently.
- Teacher notebooks have the same problem, but more rare.
- On my test with 2GHz and 5GHz of the same SSID, is it on the 2GHz that the wifi performance is incredibly bad (1-5MBit/s) on 5GHz it' jumps to 100+Mbit/s. So I startet moving the SSID from 2GHz to 5GHz only. Maybe it’s the firmware?
- Is the CCR my problem as capsman?
- Is segmentation the key?
My router config is shortend, there are many more buildings and access points, more vlans and SSIDs, but for simplification I used this snippet.
Thanks for the help!
DataDragon
PS: If someone has a good guide for a high availability setup with two CCR router gladly give it to me.
