Dear All,
I’m having trouble navigating from the Ether2 interface, and failover isn’t working for me either. I would greatly appreciate your help.
Greetings
model = RB951G-2HnD
serial number =
add admin-mac=xx:xx:xx:xx:xx:xx arp=proxy-arp auto-mac=no comment=defconf
name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
disabled=no distance=indoors frequency=auto installation=indoor mode=
ap-bridge ssid=MikroTik-334A3F wireless-protocol=802.11
/interface wireguard
add listen-port=13235 mtu=1420 name=xxxxxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.0.10-192.168.0.254
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add interface=ether2 list=WAN
add interface=Emanuel list=LAN
/interface wireguard peers
add allowed-address=10.10.10.7/32 interface=Emanuel name=peer1 public-key=
“xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx=”
add address=192.168.0.1/24 comment=defconf interface=bridge network=
192.168.0.0
add address=10.10.10.1/24 interface=Emanuel network=10.10.10.0
add address=190.xxx.xxxx.83/24 interface=ether2 network=190.xxx.xxx.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.0.132 client-id=1:xx:cx:ax:97:7c:48 mac-address=
30:CD:xx:xx:xx:4x server=defconf
add address=192.168.0.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4
gateway=192.168.0.1
set servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=accept chain=input comment=“wireguard handshake” dst-port=13235
protocol=udp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add disabled=no dst-address=0.0.0.0/0 gateway=190.xxx.xxx.254 routing-table=
main suppress-hw-offload=no
add check-gateway=ping comment=“RUTA FIBERTEL” disabled=no distance=10
dst-address=0.0.0.0/0 gateway=9.9.9.9 routing-table=main scope=30
suppress-hw-offload=no target-scope=11
add check-gateway=ping comment="RUTA IPLAN " disabled=no distance=11
dst-address=0.0.0.0/0 gateway=8.8.8.8 routing-table=main scope=30
add comment=“CONTROL PING FIBERTEL” disabled=no distance=1 dst-address=
9.9.9.9/32 gateway=181.xx.xx.1 routing-table=main scope=10
suppress-hw-offload=no target-scope=10
add comment=“CONTROL PING IPLAN” disabled=no distance=1 dst-address=
8.8.8.8/32 gateway=190.xxx.xxx.254 routing-table=main scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute”
dst-port=33434-33534 protocol=udp
“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500
protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
“defconf: drop everything else not coming from LAN” in-interface-list=
!LAN
“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1”
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Argentina/Buenos_Aires
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
