Problems Netflix / Pppoe / Eoip tunnel
Hi all
I have a problem that I don’t know how to solve.
I have 20 Wi-Fi nodes all mounted with Mikrotik. Those 20 nodes are connected to a central Mikrotik Ccr where by eoip tunnel I have those nodes connected to the main Ccr where the pppoe servers are.
Those eoip tunnels are configured with MTU 1500. The pppoe servers in MTU 1450
The networks are configured on the clients, those of Google, locally on the dhcp server, on the network. There is no DNS server.
The problem is the following:
Clients when they mask me for pppoe, Netflix doesn’t work. It doesn’t load …
If I mask over the network and the main router server, netflix works without problem. The problem comes when I mask through the pppoe.
The funny thing is that I have clients that work and others that don’t … All with the same configuration …
Through pppoe I have a radius server where my clients and my mature / 22 accounts where I assign it dynamically.
The following command was performed to determine if the MTU size is correct and there is no problem …
The problem has me crazy …
I look forward to your help, since I have many affected customers …
Thank you
Yo! have you try this? http://forum.mikrotik.com/t/problem-to-reach-some-websites/131731/1
Goodnight.
I’m going to try uploading the firmware version, but I don’t know which version to put …
Also, I couldn’t imagine that in the firewall, filter, icmp, could make that the problem.
It is right?
Thank you.
