I would like to ask help regarding our setup. I have one CCR1072-8S+ as a core router carrying 150 VLANs on bridge1 interface. Sfp-sfpplus ports 2 to 7 are all added to bridge 1. Vlan 51 to 190 are all declared on bridge1. I have a remote site (Node2) which has CRS226-2S+, sfp-sfpplus1 connected to my core CCR1072 by fiber on sfp-sfpplus2 port. CRS226 was also been configured to carry vlans 51-190, and vlan 30 (MGMT) for its ports. There are still other Node CRS switches cascaded on this node.
The problem is, my link is not stable. I have a netwatch enabled on the core, and the CRS on node2 keeps on being intermittent. Interface is up, protocol down. I cannot ping it. I have to reset the CRS at Node2 for it to be able to reestablish connection. Same with other nodes. Connection just lost for some reason I don’t know. LINKS run on 10G SFP interfaces. I have already played around, auto-negotiation, flow control, MTU 9000, to no avail. Can anyone help me? Thanks.
All VLANs gateway on Core CCR1072.
Fully Layer 2 Network
VLAN 30 - Management, across whole nodes.
Some Nodes have more than one CRS226 switch, cascaded
All links in 10G
Problem: Links are not Stable, Node to Core, or Node to Node.
Same problems, workaround is bridge all that ports to cpu, remove them from switch chip (master port) and assign to bridge, then wait for mikrotik to repair router os or buy another model 125 dont have that problem.
226 have problem with switch chip. We have same behavior as you.
As I understand the problems with your CRS226 appear when they have a bridging configuration.
We are aware of such problems and the new RouterOS v6.33 release will contain fixes for them. v6.33 will be released very soon.
In case any problems remain in the new version, please write an email to MikroTik support referring to this topic and include supout.rif file.
We have same problem. CCR1009 as a router and two CRS226 (connected with SFP+ 10G). No bridge on CRS. Clear config and IP address added. We have STP on other switches (HP). We found that connecting new switch (we can repeat it) to our topology hangs ports on CRS - but we do not know why. We can not make suppout.rif when it hangs. Powering off CRS helps.
We can make any additional test if it is needed to develop problem.
