Unfortunately it doesn’t work, it still output on WAN2 the LAN address as source, and the packet die in the next hop. It’s like it doesn’t complete the dstnat procedure, if it does, then it should have the WAN2 source IP. I don’t know why mangle mark routing, and it routes before the packet can be changed by dstnat, the packet exit form WAN2 as it comes from LAN, how can I postpone the routing after the competion of dstnat?
this is the config:
# 2023-11-10 18:31:13 by RouterOS 7.10.1
# software id = U31Z-TEGH
# model = RB750r2
# serial number = 8B3808E10A62
add admin-mac=CC:2D:E0:69:19:FA auto-mac=no comment=defconf name=bridge
add name=bridgeOVPN
set [ find default-name=ether1 ] l2mtu=1600
set [ find default-name=ether2 ] l2mtu=1600
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip dhcp-client option
add code=55 name=parameter_request_list value=0x010306212A79F9
/ip dhcp-server option
add code=6 name="DNS Alternative" value="'64.225.68.86'"
/ip hotspot profile
add name=default-dhcp ranges=192.168.101.100-192.168.101.200
add address-pool=default-dhcp interface=bridge lease-time=1w name=defconf
/ppp profile
add bridge=bridgeOVPN local-address=192.168.2.3 name=OVPN2 remote-address=\
192.168.2.1 use-ipv6=no use-mpls=no
/interface ovpn-client
add cipher=aes256-cbc connect-to=146.66.181.172 mac-address=02:A3:5E:EB:58:64 \
max-mtu=1460 name=Vdv port=44301 profile=OVPN2 use-peer-dns=no user=OVPN2
/interface l2tp-client
add add-default-route=yes connect-to=tp.internet.beeline.ru \
default-route-distance=2 disabled=no max-mtu=1460 name=l2tp-beeline \
profile=default use-peer-dns=exclusively user=0892090319
/queue simple
add name=queue4 priority=5/5 target=192.168.101.100/32
add name=queue5 priority=5/5 target=192.168.101.101/32
add disabled=yes max-limit=20M/20M name=queue1 target=192.168.0.112/32
add disabled=yes max-limit=5M/5M name=queue2 target=192.168.0.104/32
add limit-at=50M/50M max-limit=70M/70M name=queue3 target=192.168.101.116/32
/routing table
add disabled=no fib name=vdv
/snmp community
set [ find default=yes ] addresses=192.168.0.0/24 write-access=yes
/ipv6 settings
set disable-ipv6=yes
add comment=defconf disabled=yes interface=ether1 list=WAN
add interface=l2tp-beeline list=WAN
add interface=ether2 list=LAN
add interface=bridgeOVPN list=LAN
add interface=Vdv list=WAN
add address=192.168.0.10/24 comment=defconf interface=bridge network=\
192.168.0.0
add address=192.168.99.1/24 comment=defconf disabled=yes interface=bridge \
network=192.168.99.0
add address=192.168.101.10/24 comment=defconf interface=bridge network=\
192.168.101.0
/ip dhcp-client
add comment=defconf default-route-distance=5 dhcp-options=\
parameter_request_list,hostname interface=ether1
/ip dhcp-server lease
add address=192.168.101.100 mac-address=10:F0:05:CA:8A:0A server=defconf
add address=192.168.99.101 disabled=yes mac-address=D8:CE:3A:FC:C8:7D server=\
defconf
add address=192.168.101.252 mac-address=98:CD:AC:30:AF:9F server=defconf
add address=192.168.101.253 client-id=1:12:42:7d:5c:19:78 mac-address=\
12:42:7D:5C:19:78 server=defconf
add address=192.168.101.101 client-id=1:d8:ce:3a:fc:c8:7d mac-address=\
D8:CE:3A:FC:C8:7D server=defconf
add address=192.168.101.116 client-id=1:b4:2e:99:e5:95:6d mac-address=\
B4:2E:99:E5:95:6D server=defconf
add address=192.168.101.250 client-id=1:80:f3:ef:8e:32:3 mac-address=\
80:F3:EF:8E:32:03 server=defconf
add address=192.168.101.0/24 comment=defconf dns-server=\
8.8.8.8,1.1.1.1,192.168.101.10 gateway=192.168.101.10 netmask=24
set allow-remote-requests=yes servers=208.67.222.222,64.225.68.86
/ip dns static
add address=192.168.0.100 name=vdv.vdv
/ip firewall address-list
add address=192.168.0.100 list=test
add address=192.168.0.101 list=test
invalid
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward disabled=yes dst-address=192.168.2.0/24 \
in-interface=bridge src-address-list=!test
connection-state=invalid
connection-state=new in-interface-list=!LAN
established,related,new,untracked disabled=yes in-interface=bridgeOVPN
established,related,untracked
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes dst-address=\
!192.168.0.0/16 new-routing-mark=vdv passthrough=no protocol=!udp \
src-address=192.168.0.250
src-address=192.168.101.100
src-address=192.168.101.101
src-address=192.168.101.106
add action=mark-routing chain=prerouting connection-nat-state=dstnat \
dst-address=192.168.2.3 dst-port=8001 new-routing-mark=vdv passthrough=\
yes protocol=tcp
add action=src-nat chain=srcnat out-interface=Vdv routing-mark=vdv \
to-addresses=192.168.2.3
add action=src-nat chain=srcnat dst-address=192.168.2.2 to-addresses=\
192.168.2.3
add action=src-nat chain=srcnat dst-address=192.168.2.4 to-addresses=\
192.168.2.3
add action=src-nat chain=srcnat dst-port=8291 protocol=tcp src-address=\
192.168.0.100 to-addresses=192.168.2.3
add action=redirect chain=dstnat dst-address=192.168.0.100 dst-port=80 \
protocol=tcp src-address=192.168.0.0/24 to-ports=1880
src-address=192.168.101.100 to-addresses=192.168.2.3
add action=dst-nat chain=dstnat dst-address=192.168.2.3 dst-port=8001 \
protocol=tcp to-addresses=192.168.101.100 to-ports=8001
add disabled=yes distance=1 dst-address=192.168.88.0/24 gateway=192.168.0.111 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=192.168.2.1 \
routing-table=main scope=10 suppress-hw-offload=no
add disabled=no distance=8 dst-address=0.0.0.0/0 gateway=192.168.2.1 \
pref-src=192.168.2.3 routing-table=vdv scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no dst-address=192.168.3.0/24 gateway=192.168.2.2 routing-table=\
main suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=OVPN2 profile=OVPN2 service=ovpn
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=Baklazhan
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=193.204.114.232
add address=132.163.97.5
/system scheduler
add interval=1m name="Renew gateway" on-event="/ip dhcp-client renew ether1" \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=1970-01-01 start-time=00:00:01
add interval=1d name="Public IP renew" on-event=\
"/interface l2tp-client disable 0\r\
\n/interface l2tp-client enable 0\r\
\n" policy=\
start-date=2023-03-25 start-time=06:30:00
/system script
add dont-require-permissions=no name="Public IP renew" owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
\n"
/system watchdog
set auto-send-supout=yes ping-start-after-boot=10m send-email-to=\
aa@bb.cc watch-address=8.8.8.8
/tool e-mail
set address=mail.sicurezza.ru from=aa@bb.cc port=2525 user=\
service@sicurezza.ru
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=bridge filter-mac-protocol=arp
