Hello, im running 2 servers with mt 4.10 lv4 license on 2 equal AMD Phenom II x4 955 @3.2 ghz 2gbRAM @1600mhz
Regarding to nic setups i got in sv1 2 “Intel PRO/1000PT (EXPI9300PT) PCIe1x”, and the onboard realtek gigabit rtl8169
on the other sv i got the onboard (same as above) and the Intel PRO/1000PT (same as above)
SV1 is configured as Gateway Router managing NAT (for Public IPS) and general firewall.
SV2 is configured as a transparent bridged traffic shaper.
those svs are connected between them.
SV1—>SV2—>
Cisco catalyst 2924C XL
|–>Internal LAN and management.
|–>WISP AP all mt4.x on routerboards (various)
|–>PTP links (mt4.6)—>WISP APs
Every 8 to 10 minutes i get a 5 to 10 ping loss (simultaneously) in both servers.
Tests ive made:
Ping from SV1 to Internet (http://www.google.com) smooth 4ms max without loss
Ping from SV1 to SV2 ping loss every 8 to 10 minutes*
Ping from SV1 to internal lan ping loss every 8 to 10 minutes*
Ping from SV2 to SV1 ping loss every 8 to 10 minutes*
Ping from SV2 to internal lan ping loss every 8 to 10 minutes*
Ping from Internal LAN to SV1 or SV2 loss every 8 to 10 minutes*
- All at the same time
Ive also checked the cables, switches, power cords..
whenever i get the loss every connection i have on gets disconnected..
for example: if im playing an online game i get kicked!
im trying to figure out whats the problem.. i already know its in those servers but i need ur opinion.
btw, i upgraded the pcs and the problem started, before that i was running them on pentium D @3ghz with 512mb RAM@400mhz and 3com 10/100 nics. Never had loss..
can the problem be the mt 4.10? or the AMD processor? or the RAM? routing? idk…
Whatever info u need just feel free to ask and ill post it.
regards.
Pablo
