I have loaded Beta 5.4 and not sure what is going, not even sure if its the beta version.
I have had several incidents when activating the winbox the program comes up, but thats it. The data does not fill out. the program is just frozen. If I keep retrying I will eventually get it to work, sometimes no trouble, then bam, everything is frozen up! Winbox does not want to work on
my windows 7 Toshiba at times, does not activate the program. Id box, you can put info in it and if you try to change it, it keeps the original info displayed although the id box shows the new info. Finally, most important. I have nanos showing 100% on the mikrotik signal level, but the tx showing anywhere between 10 to 30% on various nanos. These nanos and the mikrotik all show signal strengths in the mid 60s to mid 70s. Thus, system is slow as dial up due to the poor tx ccq. I have disconnected each client (7 clients on this AP), manageable switch shows 8 up and 10 down. Hits the ap to client, dial up speed. Changed freq. several times, no change. Changed out rf boards and os boards (433) same. System been working fine up to a few days ago. I try to reload 3.30 but it still shows 5.4 beat on the display, didn’t help. Put 5.4 back in.
Any ideas here?
Thanks,
Larry
