Problems setting DNS?
I setup a 750Gr2 today and had some issues using the “Quick Set” page. When I add an entry under DNS Servers, it is not remembered. Is the web gui buggy?
Samuel
Try to add it through DNS menu.IP\DNS. Avoid quick set as much as you can. :slight_smile:
So is the Quick Set menu broken? I feel disappointed if that’s the case. For beginner it’s not really obvious.
Can you please provide steps how to repeat this issue? I didn’t found any problems using Webfig with RouterOS 6.33.3
