First make sure you have a DHCP client on ether1 as your WAN interface. Sounds like that’s already the case if you have a public IP on that interface via DHCP. That’s normal. Cable modems bridge those in. Make sure you have the right settings to get a default route from your ISP. http://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Client
I always remove it. I hate overloading IPv4 addresses on the same broadcast domain.
I don’t usually include the commands to remove them when posting here, though. It tends to confuse people, particularly since it only comes up with beginners.
The various new router setup guides on the wiki are worth mentioning too. Although the port knocking setup the one mentions is the type of thing that always makes me a bit nervous, and the firewall rules are a bit elaborate for a newbies SOHO config. http://wiki.mikrotik.com/wiki/Securing_New_RouterOs_Router
It’s true. It might be worth writing a long, long, long wiki article on “first steps” - but there’s just too many routers and scenarios to cover everything. And if you cover too much people think it’s too complicated.
I will try this out and post what i ended up getting.
The setup described is very similar to what I attempted earlier, but even though i received an IP from the dhcp server, I was unable to reach the router on 192.168.15.1
Also I would very much appreciate it if you did include those commands to remove the default rules.
FYI, although i’m new to RouterOS, I have worked with Cisco IOS and Juniper Netscreen Firewalls. Work as Linux Sysadmin, so i’m a systems person not a network admin.
If their is somethings i should look at (like NTP) let me know.
I don’t have a 450G around, and while I thought there was a wiki page that describes every router’s default settings I can’t find it right now.
When you reset a RouterOS device to factory defaults it’ll apply a default script on next boot, but then let you revert it. That’s probably the easiest way to clear it all out. Log in via the serial cable (just like a Cisco device, but 115200 baud instead of 9600). Then issue “/system reset-configuration” and confirm. After the reboot log in as ‘admin’ with a blank password, it should then ask tell you about applying default configuration. Press ‘r’ to revert and not apply that default script. Then issue the settings as I described earlier.
At that point you’ll have the equivalent of any given home router. Where you want to go from there is up to you - these puppies do everything up to BGP.
If you experience any issues please post back with lots and lots of details - here the commands you’d want to run to gather the relevant output: “/interface print detail”, “/interface ethernet export”, “/ip address print detail”, “/ip route print detail”, “/ip firewall export”, “/ip dhcp-server export”, “/ip pool export”, “/ip dhcp-client export”, and “/ip dns export”.
Learning how to reset the router and what the default configs are is one of those pieces of info that you just know you’re going to need. I’ve already had to do that at least once after a bad cut & paste created a firewall filter rule that locked me out.
so what actually says i want the router on 192.168.15.1?
that range could be anything 192.168.15.X
and the default is usually highest. how can i force 192.168.15.1?
and nothing seems to work anymore.
no dhcp nothing, not like it was working more then just handing out address that don’t connect. here is all my print outs.
[admin@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.15.1/24 192.168.15.0 ether1-gateway
1 192.168.15.1/24 192.168.15.0 ether2-master-local
2 192.168.15.1/24 192.168.15.0 ether3-slave-local
3 192.168.15.1/24 192.168.15.0 ether4-slave-local
4 192.168.15.1/24 192.168.15.0 ether5-slave-local
[admin@MikroTik] > ip dhcp-server print
0 dhcp1 ether1-gateway dhcp_pool1 1w yes
[admin@MikroTik] > ip dhcp-client print
# INTERFACE USE-PEER-DNS ADD-DEFAULT-ROUTE STATUS ADDRESS
0 ;;; default configuration
ether1-gateway yes yes searching...
[admin@MikroTik] > interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 ether1-gateway 1500 00:0C:42:BD:98:83 enabled none switch1
1 R ether2-master-local 1500 00:0C:42:BD:98:84 enabled none switch1
2 S ether3-slave-local 1500 00:0C:42:BD:98:85 enabled ether2-master-local switch1
3 S ether4-slave-local 1500 00:0C:42:BD:98:86 enabled ether2-master-local switch1
4 S ether5-slave-local 1500 00:0C:42:BD:98:87 enabled ether2-master-local switch1
not sure if i forgot to post anything, if so let me know.
I have decided to return the router, I want to salvage the last day of the extended weekend. I needed something to be working in a full day, we recently had a power outage and I have multiple items that need replacement/work or an RMA and just can’t put in this kind of time. I’v been working on this for a couple days now and still am almost nowhere.
Also, My router won’t even boot anymore. I really pray I can get a Refund.
I wanted something that would be a killer openwrt system, just drastically underestimated how different and difficult actually working with embedded devices could be. I also was misled by old documentation and failed to research as much as I should have.
Just wanted to thank everyone for attempting to help me, I really appreciate it!
Status Update:
Eventually got OpenWrt installed, which was the original reason I purchased the RB450G . I’m extremely happy with it, although it was a very rough first few attempts, my second RB450G was just delivered!
Sorry to hear that. My personal experience with RB was very different, within a couple hours the first night after it arrived (which was a work night) it was doing test firewall duty with the desired addresses, and by the end of that Saturday had been upgraded to RouterOS 5.5, was acting as the NTP and DNS server, had been pretty well locked down, and had tweaked logging and firewall rules. This was mainly just a matter of reading the first time setup and securing guides and walking the webfig menu hierarchy.
I wish you wouldn’t abandon Mikrotik so quickly. About me: I have little knowledge of the IT world. I’m actually a broadcast engineer, working on the studios of AM/FM radio stations. I moved to Mikrotik because I was tired of instability issues with the Linksys, Netgear, etc routers.
Like you, I started knowing NOTHING about Mikrotik. I purchased a RB750G as my first router, modified the default settings, and then began adding functions. I was successful with the 750G and now use the 450G. It does take time and some frustration, but you’ll be very happy with the router once you have it up and running.
I agree that Mikrotik sorely needs documentation for the “Newbys.” I’m glad that Fewi is writing an article on first-time configuration. I would like to see such an article that not only explains “how” but also “why”. I think such an article would go a long way in getting folks up to speed with Mikrotik basics.
