My problems are many, I have read quite the forum but I could not solve any of my concerns.
Well first is related to the proxy, it appears that on my network I have 4 interfaces, 3 LAN and 1 WAN, to each of my LAN interfaces to a given range of IP’s will give a public IP that the NAT from the firewall, there all well. The problem is when forwarding all http traffic (80) to the proxy, by doing so the ip range that gave them their public ip stops working, staying with bone WAN IP.
The other problem is also related to the proxy, it appears also that the redirect to the http proxy (80), in some cases no longer make the rules for dividing services in the “Mangle”, and consequently I can not limit since Queue Tree.
And finally the other problem is not related to the proxy, it appears that many times in my wireless network in which I have 50 clients with approximately 100ips, divided into 3LAN, many times the ping is saturated or dropped, at first I thought it was interference problem as a lot of teams change in my tower thinking that would solve my problem, but no, All my clients have very good signal (worst signal -65, -48 and on average, neither under -40 (I told them less than -40 could cause problems, not if it’s true))
And these are my 3 main problems I have like 4 months looking for a solution and nothing has given me good results.
I hope I can provide some help …
(I have an Intel RouterOS)
