Hi guys. My second problem with Mikrotik routers seems to revolve around heating, or so it seems (to me):
So, the router in question is installed. Android TV is connected to ether4 port. In about 15 - 30 minutes of watching TV, the TV loses internet connection. If I go to TVs ethernet settings it still shows its IPs (both v4 and v6), but internet connection is gone.
Yesterday I found that the issue is solved (without any rebooting) if I just move the cable to ether2. After that it worked for the entire evening.
CPU temperature right now (system/health) is 56°C. (“right now” being in the morning without any serious activity)
In addition to the above, I also have:
ether5: RB260GSP, serving a mAP lite and a cAP lite
ether3: a linksys 5-port business level switch serving two PCs
Any suggestions on what might actually be wrong with my setup?
Are you suggesting it's just the one port that might be malfunctioning? Other than that, yes, since moving to ether2, there have been no issues with watching TV.
I wonder if ether5 will have similar issues since there will be a TV connected to that one as well...
Not on both, simply is the tv or the cable, and trying another device (with another cable) on ether4, if works the problem is the TV or the cable.
(pulling out the cable disable also TV ethernet)
